jimmy64 Offline
#1 Posted : Monday, 5 January 2009 8:10:50 AM(UTC)
jimmy64
Does anyone know what fanclutch can be used to replace the fanclutch on my 307 SBC HK as this one does not appear to do much whether the car is hot or cold? The fan is a 7 blade and has 913894K67 3931002 stamped on all blades and A68V on the other side of one blade.
#2 Posted : Monday, 5 January 2009 6:02:05 PM(UTC)
Part number for the 307 clutch fan for HT is 3938944 which is a US GM part number. HK 5 blade is 3916139 and 7 blade is 3931004. The HK numbers also suit 6cyl. Have a search on a few NOS sites over there and youll find one.
Also note that HT auto 350 clu
#3 Posted : Tuesday, 6 January 2009 5:25:10 PM(UTC)
307 and first type 327 use the HK six cylinder "stud patern" on the water pump, which changes at HT and 327 second type, 350 and 253/308. So they are hard to find. best bet is the US, but HT will not fit, unless you use the multi drill pump and pulley.
