#1 Posted : Wednesday, 7 January 2009 9:00:42 AM(UTC)
Me again. Thanks to all those guys with info on the squeaky xb. I have replaced the saddles and greased up the relevat areas (covering both bases) and it is a nice quiet ride again. Cheers.
I have another query though. Can someone tell me the torque settings for the head bolts and exhaust man bolts on the precross 6? I have had to pull off the head and without a manual to get the specs I was hopng soneone might be able to help. (no point in doing it up too loose).
#2 Posted : Wednesday, 7 January 2009 10:32:36 AM(UTC)
I hate typin this stuff out...... head is 3 stages, Do all up to 1st stage, then redo to 2nd stage, then redo to 3rd stage. Check the head gasket, It may need another tighten after a week.and be sure to clean your head bolt threads well before u use them
#3 Posted : Thursday, 8 January 2009 2:59:26 AM(UTC)
Thanks soooooo much mate. I am about to put her back together now and your help is invaluable.
Docktor Offline
#4 Posted : Thursday, 8 January 2009 9:00:22 AM(UTC)
Docktor
No drama mate, glad to help.
Doc
#5 Posted : Thursday, 8 January 2009 9:48:36 AM(UTC)
Almost ready to try her out again now. The head is back on the exhaust is hooked up. Just have to put my radiator back in (yep that needed work too) and bolt up the rocker cover and carby. Not to mention playin with the timing as I have cut and grinded
Bossy Offline
#6 Posted : Thursday, 8 January 2009 7:33:20 PM(UTC)
Bossy
Ah! The joys of renovating a classic!
