basketcasebear Offline
#1 Posted : Thursday, 8 January 2009 7:26:05 AM(UTC)
basketcasebear
hey yall,
from the man who gave you the fasterest camper in the west,
well he needs to get his quadrajet carby, runnin properly,
needs a kit,,maybe??,,, because cant adjust idle air mixture screws?
could there be another reason for this??
pipes on incorrectly?? something else? leaking air?? maybe,,
or does it need a complete kit??
and if so,,,is it far beyond the capabilities of the basketcase??
to put a kit thru it??
be honest,, i can take it,,
thanks already.
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!"
and the wind did not answer, it just laughed in space.
k.g/
DOH!!!
munro73 Offline
#2 Posted : Thursday, 8 January 2009 9:52:47 AM(UTC)
munro73
a little more info would b helpful?
nah sell and get a holley heaps easier to kit
(and, oh i can hear the abuse)
but the quaddie is a better carb when running right
lol
seriously check the simple things first
you got the pollution model ?
if so pop
marge pass me my gun
#3 Posted : Thursday, 8 January 2009 10:32:49 AM(UTC)
Vacuum leak Im tipping.
#4 Posted : Thursday, 8 January 2009 1:07:44 PM(UTC)
basketcasebear
ok, munro and casper,
heres the story>>>
had good mate, who is good mechanic, pull it apart, and check it all, said it was all good,,
he is in spain somewhere,
now, starts good, runs good, but i am sure it is too rich,,
so i screwed screws
DOH!!!
#5 Posted : Friday, 9 January 2009 6:20:23 AM(UTC)
basketcasebear
well here is a pic of thee quaddy, would love to know what are the different rubber pipes coming out of it, and a general discription of how these things work?
eg, what does having a vacumm pipe connected to it,?
i know what the fuel pipe does, what the
DOH!!!
munro73 Offline
#6 Posted : Friday, 9 January 2009 6:32:53 AM(UTC)
munro73
dude wheres your vac advance hose to your dissy?
like caspar says probaly a vacum leak
#7 Posted : Friday, 9 January 2009 6:34:56 AM(UTC)
basketcasebear
hey munro will have a look,
bcb
k.g/
DOH!!!
#8 Posted : Friday, 9 January 2009 6:42:32 AM(UTC)
basketcasebear
i will have to have a cook tomorrow,
bcb
k.g/
DOH!!!
#9 Posted : Saturday, 10 January 2009 5:02:26 AM(UTC)
basketcasebear
well munro, casper,
had a look,,and i have never seen so many hoses going no where,!!!
is there somewhere i can go, to see a diagram of a quaddy, that shows where all these hoses
should go??
i did find one hose, at the back, with a bolt in the end, t
DOH!!!
#10 Posted : Saturday, 10 January 2009 5:22:37 AM(UTC)
If you block any of these hoses while its running does it effect the way it runs?
If so, that hose should be fitted to something or blocked off.
Also, what is the idle speed? If it is too fast, the mixtures screws wont make much difference to the way it
munro73 Offline
#11 Posted : Saturday, 10 January 2009 6:30:04 AM(UTC)
munro73
ok you runing an auto cause i can c that ones not connected and on you dissy at the back is a pipe thats not connected check these and any others like casper says and then check your idle screws timing etc
most of the pipes are for emission so can be mad
#12 Posted : Saturday, 10 January 2009 8:01:21 AM(UTC)
basketcasebear
thanks fellas,
i will idle it down to about 7>800revs
and use pliers to choke all pipes off, one at a time, see if makes a diff,?
thanks gives me a start on fault finding.
bcb
DOH!!!
munro73 Offline
#13 Posted : Saturday, 10 January 2009 8:13:33 AM(UTC)
munro73
oh to reset your idle screws you seat them then back off 1 and a half turns check timing ajust if ness
fine tune idle screws
alby
musksell Offline
#14 Posted : Sunday, 11 January 2009 8:25:03 PM(UTC)
musksell
mine I just replaced whole carb....the shaft was a bit worn causing idle to go up and down a bit...
This page was generated in 0.116 seconds.
