#1 Posted : Friday, 9 January 2009 4:52:23 AM(UTC)
just want to know to vt brake calipers fit a vn
hatchssv8 Offline
#2 Posted : Friday, 9 January 2009 5:52:38 AM(UTC)
hatchssv8
I suppose you are refering to the front brakes. If that is the case then yes the VT calipers have the same footprint on the bottom of the strut. To fit the VT rotor hat you will also need a hub. And your master cyl should be a 1" bore for 4-wheel disc se
#3 Posted : Friday, 9 January 2009 7:58:27 AM(UTC)
Hi damien.
You will also need custom front brake hoses, that fit the VT caliper at one end & the VNs inverted flare pipe end at the other. VT hoses are too short & dont match the VNs pipe end.
If you are in Sydney I make these to order in either fa
