Rod32320 Offline
#1 Posted : Sunday, 6 April 2008 8:30:35 PM(UTC)
Rod32320
Just after some advice, I have an FJ still running a grey motor but through a supra 5 speed. Still using the original clutch setup and brake master cylinder, now after 2 years of it being on the road I've finally decided to put disc brakes on it and as I want to change to a twin circuit brake setup and hydraulic clutch, I need to know what pedal box, clutch and brake master cylinders/booster to use. I want something thats reasonably modern and easy to get hold of, I don't want to use fc/ek stuff.
Thanks in advance
Rod
