Rhys Offline
#1 Posted : Monday, 12 January 2009 8:11:53 PM(UTC)
Rhys
Hi All,
Does anyone know if HZs / WBs with the buckskin trim (63) had a tan (67) dashpad/glovebox/lower dash etc or were they a colour of their own. The dashes in buckskin vehicles isnt obviously the light buckskin colour but is it tan or a shade or two lighter? I know the column and wheel is darker than the trim/console/door trims etc but still not as dark as tan.
I've found that the WB Oyster is definitely a colour of its own with no tan components.
Any help much appreciated.
Rhys
HZute-efi-VS5L Offline
#2 Posted : Tuesday, 13 January 2009 4:20:01 AM(UTC)
HZute-efi-VS5L
Rhys,
this applies to the HZ GTS.
The cloth insert buckskin dashes have a lighter coloured crash pad that is the sand paper look finish.
The non insert buskskin have a tan crashpad with a slightly lighter coloured glovebox (but the glovebox is darke
www.stickthisdecals.com.au
Rhys Offline
#3 Posted : Tuesday, 13 January 2009 5:25:32 AM(UTC)
Rhys
Hi Jason,
Thanks for the info - the non-insert buckskin on the HZ GTS sounds like the same combination of seats/dash/glovebox as the WB Kingswoods with trim 63V.
If you wouldnt mind emailing me those pictures that would be great, thanks.
Rhys
hainzy Offline
#4 Posted : Tuesday, 13 January 2009 7:41:14 AM(UTC)
hainzy
This is a pic of my sandman HZ interior. You can see the colour differences.-
hzsandman Offline
#5 Posted : Tuesday, 13 January 2009 7:54:16 PM(UTC)
hzsandman
My HZ Sandman which is 63V trim as well seems to have a darker brown on the dash pad and glove box compared to the posted pic (although it may just be the photo).
Any more pics of standard 63V trim would be appreciated.
My dash and glovebox are in t
peterwmh Offline
#6 Posted : Tuesday, 13 January 2009 9:03:24 PM(UTC)
peterwmh
I have a spray pack of buckskin paint I was going to use on my HZ Prem but sold it before I did any work on the interior. Happy to sell you the tin I have, should be fine still, is around 2 years old and has been in a cool garage under my house. Id be h
#7 Posted : Wednesday, 14 January 2009 12:50:05 AM(UTC)
HZute-efi-VS5L
Ok its a strange one....
From the pics i have of HZs (i have hundreds of pics) for 63V trim.
HZ GTS with The cloth insert - have the coloured crash pad that is the sand paper look finish like in hainzys pic.
HZ GTS non insert buskskin have a tan c
#8 Posted : Wednesday, 14 January 2009 12:56:34 AM(UTC)
Hi Guys.
The dashpad with the grain (regardless of colour) was fitted to all HZ models at introduction. In late 1978, Commodore type trim materials were introduced to replace the grain finish, across all HZ models. The Commodore material has the fine s
Edited by user Wednesday, 14 January 2009 1:01:02 AM(UTC)  | Reason: Not specified
hzsandman Offline
#9 Posted : Thursday, 15 January 2009 12:11:17 AM(UTC)
hzsandman
Thanks Peter, but I have changed the interior to Black. I was interested as I still have some original bits and pieces for the interior in the original buckskin but they need a refresh spry. I dont need it at the moment just thought there might be a ret
#10 Posted : Thursday, 15 January 2009 2:27:36 AM(UTC)
That glovebox is out of an early HZ, it has the early type lock barrel.
These changed to the black plastic style for ADR25A in early 1978.
Dr Terry.
Mr.Jones Offline
#11 Posted : Thursday, 15 January 2009 7:08:05 PM(UTC)
Mr.Jones
Hi fellas there are some pics in my O/H shed http://gallery.oldholden...r+Codes/HZ/63+Buckskin/ if you have a look around you can find most of the other trims too.
cheers Leroy
"Planet earth is the asylum to which the rest of
Voltaire
#12 Posted : Thursday, 15 January 2009 8:19:32 PM(UTC)
HZute-efi-VS5L
Originally posted by Dr Terry
Hi Guys.
Rhys Offline
#13 Posted : Friday, 16 January 2009 1:34:39 AM(UTC)
Rhys
Thanks for all the information guys, Ive learnt a lot!
Holden sure did like offering heaps of different colour combinations in the 70s and 80s.
Pity that Holden didnt put the colour code after a lot of the part numbers (even though they do on the pa
#14 Posted : Saturday, 31 January 2009 10:53:43 PM(UTC)
From the Master parts catalogue, the different codes had different colours for some dash parts. My 11/79 HZ Kingswood has 63C code trim and the catalogue states that its buckskin for most parts (code 63T is the same) but dark buckskin for horn bar, lower
This page was generated in 0.113 seconds.
