#1 Posted : Monday, 19 January 2009 5:21:52 AM(UTC)
G`Day All,
I got a WB ute with a 202 blue motor in it and a recently installed GTS dash from a WB (factory).
Replaced the oil pressure switch with a sender from a VK commodore (fella at the wrecker said it should be the same) but now the gauge seems to read reverse to what it should be.
Did we do something wrong besides getting the wrong sender?
What motors can I get an a sender from to suit my 202 blue motor?
#2 Posted : Monday, 19 January 2009 6:06:15 AM(UTC)
The fella at the wrecker was wrong. You need one from an HJ/X/Z or LH/LX Torana.
If you are buying one new, use VDO part number 360-003.
