#1 Posted : Monday, 19 January 2009 8:11:01 AM(UTC)
HI FELLAS CAN SOMEONE HELP OUT WITH THE DIFFRENCE IN A M20 AND A M21 GEARBOX FROM A 72-73 TORANA GTR 6CYL BOX HOW MANY RINGS SHOULD IT HAVE THANKS COREY
vintageholden Offline
#2 Posted : Monday, 19 January 2009 8:27:33 AM(UTC)
vintageholden
i think m21 is v8
#3 Posted : Monday, 19 January 2009 8:33:59 AM(UTC)
I DO NO THEY MADE A M21 6CYL BOX FOR FOR GTR THAT WAS WHAT THEY HAD IN THE 72-73 BATHURST XU1 THAT WHY THESE GEARBOXES ARE HARD TO COME BY.
adam PERTH Offline
#4 Posted : Monday, 19 January 2009 8:45:08 AM(UTC)
adam PERTH
double knotch is a good chance its a M21 box, 6 or 8.. just to keep it relatively simple
if you do a search on this you will find there are some exceptions to the rule in more detail.
WANTED:
QR 662xxx
1984 WB oyster crashpad
1x15x8 Cheviot armo
PISTOF Offline
#5 Posted : Monday, 19 January 2009 9:01:05 AM(UTC)
PISTOF
Remove the side cover and youll see a number, M20 ends in 496, M21 ends in 497.
No idea how to tell if its from GTR or XU1.
Edited by user Monday, 19 January 2009 9:03:39 AM(UTC)  | Reason: Not specified
#6 Posted : Monday, 19 January 2009 9:47:17 AM(UTC)
The number PISTOF speaks of is stamped on the cluster gear.
#7 Posted : Monday, 19 January 2009 4:15:54 PM(UTC)
#8 Posted : Monday, 19 January 2009 10:02:45 PM(UTC)
ON CLUSTER READS HOLDEN 2820694 WE .ON MAIN SHAFT IT HAS HOLDEN U 921 WT .AND FIRST GEAR IS 3-74 AND IT IS AUSSIE 4 SPEED OUT OF 73 GTR SO NO NUMBERS POSTED MATCH SO COME HOLDEN FANS HELP CHEERS COREY
#9 Posted : Monday, 19 January 2009 10:12:47 PM(UTC)
Its an M22 6cyl box (commonly called a 1-tonner box). Very wide ratio box. Its not a GTR box. These were normal M20 boxes.
