Hey all, I'm chasing a xg radiator 93 model auto needed asap. cheers (Ballarat area)
You are a member of these groups:: Moderator, Registered, Veteran
Forgive me if I'm wrong but didn't the XG ute use the same crossflow radiator as the XD/XE/XF falcon?
xg's are an oddball bit of gear.I have one,just converted to injected windsor.The radiator header tank is on the passenger side buy the firewall,& the power steering boxs are also different.They look the same as xa-f but the fittings in the top are differ
Yeah they are a one of radiator I have rang so many places to try and find one but no one has one to fit I can only get one new for $350
Hi Meecar.Was looking thru me shed & found my radiator i took out of my XG.Was working fine when i took it out.You can have it for $80 + freight,i am in QLD Regards Henry
Hey mate would you know the price of freight to ballarat (vic 3355)
Hi Meecar.Postage will be $40 registered mail Regards Henry
thanks for that mate but it turns out that the radiator is good but the head has a hair line crack and thats what is makin it over heat i will keep you in mind when i need on tho. cheers
You got an airbox for an XG floating around that shed of yours Henry Heaven??
