#1 Posted : Wednesday, 21 January 2009 6:55:36 AM(UTC)
Hi Guys,
Im wiring up a new CD player in a WB ute. The ute has had a few wiring modifications in the past so I'm fixing those up as I go.
The fuse panel for the radio only has power when the ignition is on. Being a Holden novice I'm not sure if there is suppose to be accessory power on this model.
Is there an accessory position on the ignition or not?
Chris
#2 Posted : Wednesday, 21 January 2009 7:07:36 AM(UTC)
There should be. I think there should be a connector behind where the radio goes with 2 x pins on it. From memory one is yellow? and one is grey (lights). The yellow should be accessory feed. If not pull out the screw that holds the fuse box in and look a
#3 Posted : Wednesday, 21 January 2009 7:12:20 AM(UTC)
Thanks.
Ive checked the fuse box and its only powered on when the ignition is "on". The steering column has been apart as well so it is possible that the problem lays there.
#4 Posted : Wednesday, 21 January 2009 7:29:31 AM(UTC)
#5 Posted : Wednesday, 21 January 2009 9:16:49 AM(UTC)
Doh!!
Yes its does!
74HJLS Offline
#6 Posted : Wednesday, 21 January 2009 10:04:38 AM(UTC)
74HJLS
Hey Chris, I can see where you were coming from, both my kids had the same problem.
Pete.
Pete.
