klompy Offline
#1 Posted : Saturday, 24 January 2009 5:53:29 AM(UTC)
klompy
My wipers have stopped,what do I check or is it most likely the motor.Did melt the 2 thin wires from the starter motor on the headers but dont know how or if this could be part of it.Thanks Mike.
cheezel308 Offline
#2 Posted : Saturday, 24 January 2009 6:14:54 AM(UTC)
cheezel308
the wires would be a good start,or try the fuses.
HQforme Offline
#3 Posted : Saturday, 24 January 2009 10:54:26 AM(UTC)
HQforme
I fixed the squirters in mine, only to find that water got in through the seal in the built-in pump unit and it fried the internals. I relaced and re-soldered what i could, cleaned the armature, did everytihng, and it never worked.
So i went to the wre
"Silly modern cars"
klompy Offline
#4 Posted : Saturday, 24 January 2009 4:57:49 PM(UTC)
klompy
Hi I have 12 volts at the motor plug in the yellow wire,and cant see any blown fuses in fuse box but there is no fuse labelled wiper any way,Thanks.
cheezel308 Offline
#5 Posted : Saturday, 24 January 2009 6:43:12 PM(UTC)
cheezel308
the wiper fuse is the third one down on the left (or first big fuse on left side) make sure all plug are connected to the back of fuse box!
klompy Offline
#6 Posted : Saturday, 24 January 2009 11:27:33 PM(UTC)
klompy
Thanks for the advice guys it was the bottom bearing siezed a good clean out and a bit of grease and its as good as new.Thanks.
