You have been a member since:: 2/09/2015(UTC) Posts: 43,977
Did Holden ever make a remote vaccumn tank that ran off a main booster,similar to the XY GT Fords. I am using a datson booster and a Ford master cylinder and the pedal "feel" is ok but could be better. I am limited for space as the master cylinder and booster are under the floor.Brakes are commodore calipers front and ford drum rear. Any help would be great.
Ford only put that tank in because there was little or no vaccum at high revs. It will not boost your vaccum as such only give you a bit more of it.
Cheers, Pete. Old Holdens never die, they just go faster. |
