satanic customs Offline
#1 Posted : Friday, 30 January 2009 4:04:49 AM(UTC)
satanic customs
more qs about this swap...
i found a hg ute with power drum front, the cars stuffed but brimming with good bits, what i would like to know is for argument sake can i bolt up the complete stubs discs etc from a wb i have lying around? so the hg would be power disc front? the hg's master cyl is a big nut.
also with the stud pattern change on the rear do you get hg axles redrilled or what?
#2 Posted : Friday, 30 January 2009 7:03:16 AM(UTC)
Gday, Im pretty sure the booster for the power-drum brakes is only a single diapraghm booster where as the factory disc brake boosters are a twin so it would probably struggle with a disc brake front end. Probably see you at Toowoomba swap. Cheers, Tony.
#3 Posted : Saturday, 31 January 2009 8:08:45 AM(UTC)
you shall, and dont forget that mould! eight mile plains swap this sunday at the primary school on cnr logan and rochedale roads tony!
