SUSPCT Offline
#1 Posted : Monday, 14 April 2008 8:56:02 PM(UTC)
SUSPCT
Just wondering all you guys with HQ's what fuel system you are running, i removed my tank saturday to add a sump and twin pickous to the REAR of the tank, my tank was previously modified and a bigger pickup was welded in on the FRONT at the bottom this still wasnt enuff to flow my enigine.
So i have that part sorted now the fuel pump issue, nearly all pumps need to be mounted LOWER then the fuel tank to work at 100% capacity, here lies the problem on aHQ where can you mount it lower then the tank itself? its near impossible?
so what have others done to fix this issue?
