HJHeaven Offline
#1 Posted : Saturday, 7 February 2009 10:25:26 PM(UTC)
HJHeaven
Hi All
Getting ready for big als poker run and was hoping that someone could tell me how to:
(a) remove the top part of the back seat; and
(b) pull out the cardboard insert on top of the parcel shelf.
in a 4 door HJ GTS
Any help appreciated.
Thanks in advance
Mark
I am not allowed a mistress so i got a GTS - and its better
A GTS/4 is a monaro - so nuuur
LHQ-253 Offline
#2 Posted : Saturday, 7 February 2009 10:49:11 PM(UTC)
LHQ-253
Hi Mark,
First you need to remove the lower (bum) section of the seat, then undo the 2 seat belt bolts with the big washers. Then slide & lift the back section upwards with a bit of force, and it should clear the hooks that hold it.
Then undo the upper
