edmundo Offline
#1 Posted : Thursday, 12 February 2009 6:07:17 PM(UTC)
edmundo
want to remove/install a cam. on my HQ, 308. without taking motor out, can i remove the grill and slide out, or do i have to take off the front.
Also, i want to install an electronic dizzy. Which is the best dizzy to install?
666 Offline
#2 Posted : Friday, 13 February 2009 6:14:34 PM(UTC)
666
Im not sure if you can, but if you can get the centre of your motor(just above the Balancer) to line up to a gap in the Nose cone then you can do it.
Often you can move your engine a couple of inches in all directions to find a gap by jacking your engi
666
This page was generated in 0.753 seconds.
