Ado Offline
#1 Posted : Sunday, 15 February 2009 4:27:18 AM(UTC)
Ado
My NL 4litre Fairlane wont fire. It turns over but just wont start. While turning over the gauges move and then switch off and the trip computer starts showing 0 range/fuel.
This happened after cleaning the car under the bonnet,degrease and bit of a hose down. First time ever its broken down in 10 years, hope this gremlin is not my fault.Just wondering if anyone has any ideas on what might be the problem.
Thanks alot
Ado
#2 Posted : Sunday, 15 February 2009 4:33:12 AM(UTC)
Did NL/EL go back to dizzys? Is there moisture in the cap? I would suspect maybe one of the relays near the battery may have water in its housing?
Ado Offline
#3 Posted : Sunday, 15 February 2009 6:21:49 AM(UTC)
Ado
I think it has got a dizzy under the intake manifold. Tried to spray it with crc as best i could. May have to think of a way to get better access, might also be a coil there to somewhere. Have to check those relays as well. It seems strange how the gauges
landy351 Offline
#4 Posted : Sunday, 15 February 2009 8:09:46 AM(UTC)
landy351
Its very common for the coils to fail and there a bastard to get to.
Ado Offline
#5 Posted : Tuesday, 17 February 2009 10:08:32 PM(UTC)
Ado
Thanks landy351. Cant even see the coil from above. May have to call in a mechanic or auto electrician.
Ado
#6 Posted : Wednesday, 18 February 2009 3:09:55 AM(UTC)
You replace the coil from underneath the car. it's bolted to the side of the block below the inlet manifold and above the starter motor.
Driving through a puddle can crack and stuff them so washing the engine is a lot worse.
Always wash the engi
Ado Offline
#7 Posted : Monday, 23 February 2009 8:33:05 PM(UTC)
Ado
Thanks Jim5.0. Exactly what the mechanic told me to do. Cheers.
