WBLJE Offline
#1 Posted : Sunday, 20 April 2008 6:26:50 AM(UTC)
WBLJE
can any one work out which wheel below would be needed for a hq-wb.
offset/rear
spacing
15x8 5x4.75 -19mm 3.75" 726
15x8 5x4.75 0mm 4.5" 726
15x8 5x4.5 -19mm 3.75" 726
15x8 5x4.5 0mm 4.5" 726
15x8 5x5 -19mm 3.75" 15x8 6x5.5 -19mm 3.75" 726
15x8 5x5.5 -19mm 3.75" 726
mrhqute Offline
#2 Posted : Sunday, 20 April 2008 7:12:12 AM(UTC)
mrhqute
wheel bolt pattern is 5x4.75, not sure which back space would fit best.
WBLJE Offline
#3 Posted : Sunday, 20 April 2008 7:35:51 AM(UTC)
WBLJE
now the thread got posted its gone a bit haywire.the 19mm or 0mm is the offset and the 3.75"/4.5" is the rear spacing.i think the 726 is just a model or code......cheers mrhqute for the info.
adam PERTH Offline
#4 Posted : Sunday, 27 April 2008 6:36:11 AM(UTC)
adam PERTH
i would use 0mm offset on HQ which is 5 on 4.75 stud pattern
19 mm offset would be for commodores.
the terms negative and positive offset can be confusing.
have a look at:
http://www.dragway.com.au/m_24.asp
Edited by user Sunday, 27 April 2008 6:39:27 AM(UTC)  | Reason: Not specified
