monro350 Offline
#1 Posted : Monday, 23 February 2009 2:26:49 AM(UTC)
monro350
I noticed that I didn`t have any back brakes on my brougham the other day.
The pedal reaches the floor, can still can feel the front brakes.
Lucky I was close to home.
I`ve checked brake fluid and all ok, no leaking of wheel cyclinders.
please help.
HT 350 Offline
#2 Posted : Monday, 23 February 2009 2:31:49 AM(UTC)
HT 350
Sounds to me like the back brakes need adjusting (drums rear?) . nip em up!
JBM Offline
#3 Posted : Monday, 23 February 2009 2:31:49 AM(UTC)
JBM
If you have discs on the front you will have a proportioning valve either built into the master cylinder or separately mounted in the engine bay, this is most likely the problem if youre not losing fluid.
Get to a mechanic ASAP.
James
#4 Posted : Monday, 23 February 2009 3:35:48 AM(UTC)
There is no proportioning valve on HK/T/G models.
The problem is youve got air in the system or you have a faulty master cylinder.
monro350 Offline
#5 Posted : Monday, 23 February 2009 6:48:13 AM(UTC)
monro350
Thanks for the info..
