alchupanibre Offline
#1 Posted : Sunday, 1 March 2009 7:44:23 AM(UTC)
alchupanibre
hey guys.
how much and much work would it be to convert a 308 with a supra 5 speed to a 202 with either column 3 speed or the 4 speed floor shift.
cheers.
#2 Posted : Sunday, 1 March 2009 7:54:57 AM(UTC)
Not hard at all. Both of those are standard fitment to HQ.
#3 Posted : Sunday, 1 March 2009 7:58:34 AM(UTC)
alchupanibre
okay, what about throttle control? what would i have to change in the car?
#4 Posted : Sunday, 1 March 2009 8:08:44 AM(UTC)
hq`s are linkage not cable, just get a 6 cyl linkage set up from a wreck.
#5 Posted : Sunday, 1 March 2009 8:14:58 AM(UTC)
alchupanibre
alright yeah i mean the linkage. do they fit into the same place? what else do i have to change underneath the car? its a prem and probably originally a V8.
#6 Posted : Sunday, 1 March 2009 7:47:54 PM(UTC)
Nothing. Just get an engine and box from a HQ-WB 6cyl 3spd or 4spd. If the car was a V8 youll just need a V8 tailshaft as the V8 will have a Salisbury diff. The only thing to be wary of is the clutch setup. HQ and HJ are different to HX-mid HZ and late HZ
#7 Posted : Monday, 2 March 2009 3:18:04 AM(UTC)
if his not changing his diff he wont need change his tailshaft, with the clutch situaton the rat trap set-up (clutch mechanism) is the same from 6 to 8, the difference is the bracket that bolts onto the bellhousing
if it wasnt for the last minute id ge
