rustyenz Offline
#1 Posted : Tuesday, 3 March 2009 9:45:56 AM(UTC)
rustyenz
Can anyone shed some light on this problem,I have 05 vz aclaim which some time ago i brought some 19s rims and tyers for it second hand near new,both front inners worn out over time so i kept a eye on them till i just brought new tyers and of cause wheel ali to boot,which was way out causing inners to ware.Now when i turn left or right or going round round abouts the ESP kicks in on the front wheels,never done this before regardless what speed i was doing.Tyers are 235x35x19 no noise drives spot on.Old tyers were 245x35x19.
#2 Posted : Tuesday, 3 March 2009 4:23:53 PM(UTC)
Did you only change the front tyres or all 4?
The modern systems are so sensitive, that a variance in tyre size from front to rear can throw them out of whack.
A lot
rustyenz Offline
#3 Posted : Tuesday, 3 March 2009 7:08:00 PM(UTC)
rustyenz
Yeah ta Mick,changed all 4,your right they are so sensitive,thats what is hard to understand why its doing that,even checked the conections on all 4 wheels to see if prop on,stab in the dark,should i disconect batt for reset!!!
