HJHeaven Offline
#1 Posted : Friday, 6 March 2009 9:51:15 AM(UTC)
HJHeaven
Hi All
I am looking to pick better brains than mine.
I would like to try and get a little more out of the HJ 308 in a GTS/4 (partial pollution).
At the moment it has:
A mild cam
pacemaker extractors
Recon rochester carb.
Just in case its relevant, running supra 5 speed and, i think, 2.38 diff and goes nice when all 4 barrels are open.
Everything is running well but a little more poke off the line would be great.
I know its a very general question but has anyone got some ideas?
Mark
I am not allowed a mistress so i got a GTS - and its better
A GTS/4 is a monaro - so nuuur
HQforme Offline
#2 Posted : Friday, 6 March 2009 10:25:57 AM(UTC)
HQforme
Poke off the line? Lower diff gears. Depending on the ratios in the 5 speed, youd probably still be fine down the freeway (if you do that often) even with something in the low to mid 3s in the diff.
"Silly modern cars"
#3 Posted : Friday, 6 March 2009 5:54:43 PM(UTC)
A 2.78 diff with a 5spd as HQforme says is not the best combo, although 1st gear in a Supra with the 2.78 probably ends up the same as an M21 with a 3.36. Id look towards a 3.36 anyway.
If we all
pont69 Offline
#4 Posted : Friday, 6 March 2009 6:59:59 PM(UTC)
pont69
HJHeaven, what type of diff are you running?
i have a few ratios around here somewhere.. let me know what type of diff.
Cheers, James
Cheers, James
HJHeaven Offline
#5 Posted: : Friday, 6 March 2009 8:21:12 PM(UTC)
HJHeaven
Thanks everyone.
Pont69, I think it might be the 2.78 (but only based on the fact that this was what was originally in the car).
Is there anyway i can tell be looking at it from the outside?
Mark
HJHeaven Offline
#6 Posted : Friday, 6 March 2009 8:22:53 PM(UTC)
HJHeaven
To the cheese eating surrender monkey,
Thank you for your observation. I just wasted a few seconds of my life reading your response which could have been better spent plucking nasal hair.
.....and now I will never get those seconds back.
I am n
H81837Q Offline
#7 Posted : Friday, 6 March 2009 9:53:59 PM(UTC)
H81837Q
Originally posted by HJHeaven
Thanks everyone.
Edited by user Saturday, 7 March 2009 1:13:08 AM(UTC)  | Reason: Not specified
vintageholden Offline
#8 Posted : Friday, 6 March 2009 9:58:25 PM(UTC)
vintageholden
HJHeaven Offline
#9 Posted : Friday, 6 March 2009 11:43:45 PM(UTC)
HJHeaven
Hi H81837Q
Thanks for that, Ill have a look.
I think roughly, about 2500 - 2800 for 100km per hour.
Havent looked that recently.
Mark
pont69 Offline
#10 Posted : Saturday, 7 March 2009 1:09:56 AM(UTC)
pont69
hey mate.
I have a banjo 3.55 centre here.
and if your after a salisbury centre.. for the right $$$ ill part with my 3.55 LSD ute centre.
Cheers, James
Cheers, James
HJHeaven Offline
#11 Posted : Saturday, 7 March 2009 1:13:42 AM(UTC)
HJHeaven
Thanks James
Whats the difference between the Banjo and Salisbury - is it different sizes and casings?
Which one would slip stratight in?
Mark
H81837Q Offline
#12 Posted : Saturday, 7 March 2009 1:19:19 AM(UTC)
H81837Q
Hi H81837Q
pont69 Offline
#13 Posted : Saturday, 7 March 2009 2:26:44 AM(UTC)
pont69
hey HJ.
Depends whether you have a sal or banjo?
im not sure about your model.. i only know bout the HQ premier :p seeing as thats all i have.
Let me know. and ill see what we can do
Cheers, James
Cheers, James
HJHeaven Offline
#14 Posted : Saturday, 21 March 2009 9:13:09 PM(UTC)
HJHeaven
Hi guys
taken me a while to get off me behind.
Where am i looking on the diff for the identifier telling me what model it is.
Is it on the back, top/bottom or side or from top/bottom.
Mark
musksell Offline
#15 Posted : Sunday, 22 March 2009 8:02:37 PM(UTC)
musksell
2.78 with supra 5 spd (depending on tyres) would be doing 1900revs at 100km appox. 5th gear is a 20 percent o/drive.
HJHeaven Offline
#16 Posted : Monday, 23 March 2009 1:15:03 AM(UTC)
HJHeaven
That seems to be about bang on, Musksell.
I will get it up this arvo and double check.
Then I might be in the market for 3.36 or 3.55 gearing - anyone got anything (Pont69, i think you said you did)?
#17 Posted : Monday, 23 March 2009 1:24:54 AM(UTC)
vintageholden
if its a sailsbury 10 bolt it will have a plate that comes off...
inside on the crown wheel will tell the ratio
not sure of other models
HJHeaven Offline
#18 Posted : Monday, 23 March 2009 4:47:51 AM(UTC)
HJHeaven
Hi guys,
Done some checking today.
Turns out, i already have a 3.55 sal and am doing about 2300 - 2400rpm for 100kmh.
That means then, 308, mild cam, rochester, extractors, 3 inch twin system, 5 speed supra box, 3.55 sal diff.
I spose based o
HJHeaven Offline
#19 Posted : Monday, 23 March 2009 8:24:58 PM(UTC)
HJHeaven
Hi all
I should say that i plan on stroking it at some time in the future, so something compatible with that would likely be best.
Mark
Guest (8)
