#1 Posted : Saturday, 26 April 2008 11:04:38 AM(UTC)
I have just fitted a new exedy cluch to my 308. I had the flywheel ground and noticed that the grind was in the opposite direction to the one i had on the car. now when i reverse or start in first gear there is so much clutch shutter it sounds like the gearbox has blown up.if you have the revs up and pop the clutch it is ok. no good for backing up in a carpark.
any ideas would be great
