aidanhq Offline
#1 Posted : Saturday, 14 March 2009 11:05:41 AM(UTC)
aidanhq
Wanted! In Perth Only thanks
TH400 Trans cooler lines
3 bolts and spacers for bolting powersteering pump (bracket) onto the block (or length/dimensions)
and
Bolt that goes through alternator bracket and alternator
Also chasing, Linkage Rod for TH400 to Holden(turbo) shifter
#2 Posted : Saturday, 14 March 2009 7:58:20 PM(UTC)
Was thanked: 632 time(s) in 594 post(s)
Go looking for rear seatbelt spacers off VNs for power steer spacers. The ones with flat (not stepped) ends are near to identical to originals. Rare Spares sell repros as well.
If we all had the
aidanhq Offline
#3 Posted : Saturday, 14 March 2009 10:14:59 PM(UTC)
aidanhq
any shops i can go to for the trans cooler lines and linkage to suit turbo 400???
Anyone got bolt sizes im after?
aidanhq Offline
#4 Posted : Sunday, 15 March 2009 9:54:21 AM(UTC)
aidanhq
anyone got any help for me?
I tried auto pro, auto one, repco etc for 5/8 brake or fuel steel lines so i could bend/flare the lines in a shape that would suit me for my transmission cooler lines but no one can help me???
strange anyone got any help?
69HT_MUNRO Offline
#5 Posted : Sunday, 15 March 2009 10:02:50 AM(UTC)
69HT_MUNRO
Try a local Brake and clutch, transmission place, Maybe Enzed if you have a local one.
They may be able to help or point you in the right direction.
Cheers Stephen
Be careful about reading health books. You may die of a misprint.
[email protected]
http://gallery.oldholden.com/69HT_MUNRO/
#6 Posted : Sunday, 15 March 2009 8:52:40 PM(UTC)
Also try an auto LPG fitter. Last trimtic I fitted to a manual WB ute we used copper LPG pipe (plastic coated) which is the same size. I supplied the nuts and the LPG fitter flared the ends for me. You can also buy a flare tool from most tool places prett
aidanhq Offline
#7 Posted : Sunday, 15 March 2009 10:13:30 PM(UTC)
aidanhq
anyone that owns a 308 know the length of the bolts that bolt the power steering pump bracket onto the block???
can anyone measure one for me please?>
cheers for the imput
Luke in SA Offline
#8 Posted : Thursday, 19 March 2009 7:25:42 AM(UTC)
Luke in SA
Pity that you want these items in Perth only..
"3 bolts and spacers for bolting powersteering pump (bracket) onto the block (or length/dimensions)
and
