HQforme Offline
#1 Posted : Sunday, 15 March 2009 11:00:56 AM(UTC)
HQforme
See "Fresh motor just started smoking".
Pulled the head off tonight to find 5 and 6 are glazed. Dammit! I made sure to bed the motor well, used the right oil at the beginning, etc. Now glazing is commonly due to excess fuel, and all my motor problems have been since i went to twin carbs.
Could a previously fine bore glaze up with the new carbs if theyre rich?
But worse, the reason i've been CHEWING oil and blowing smoke? The PCV seems to be sucking oil straight from the rocker cover, into the manifold. There was oil in the manifold and intake ports.
Anyone ever heard of this?
"Silly modern cars"
petaus Offline
#2 Posted : Sunday, 15 March 2009 6:43:56 PM(UTC)
petaus
i would of done a cylinder leak down test befor pulling it down, if you dont have one a good perfomance shop would, if they were any good.
this would of givin you a good idea as to condition of rings etc,
is it the correct pcv valve for the engine? as w
#3 Posted : Sunday, 15 March 2009 9:48:14 PM(UTC)
Originally posted by petaus
also i remember the pcv hose going goin to the base of the carby, i prefer that than plumin
HQforme Offline
#4 Posted : Monday, 16 March 2009 2:15:28 AM(UTC)
HQforme
Thanks for the input.
I had a leak-down test lined up but as it was at a mates shop, for free, it had to yield to customer work. I had this weekend off and had to get stuck in to the work.
The shop that did the final tune claimed the air/fuel was ok
Edited by user Monday, 16 March 2009 2:16:31 AM(UTC)  | Reason: Not specified
"Silly modern cars"
petaus Offline
#5 Posted : Monday, 16 March 2009 4:17:20 AM(UTC)
petaus
ahh dr t your showing your age, lol hr a bit befor my time.
hq do you give this thing a hard time? it,s not filling the rocker cover up full of oil is it?
HQforme Offline
#6 Posted : Monday, 16 March 2009 7:18:56 AM(UTC)
HQforme
At absolute most it sees 5000, and thats not often. I drive it firmly, but never thrash it. Its a full rebuild with head work, cam, alloy gears and twin carbs, so its not like pushing a stocker.
Rocker cover does see a fair bit of oil, but using roller
"Silly modern cars"
jimpram Offline
#7 Posted : Friday, 20 March 2009 7:28:02 AM(UTC)
jimpram
Please note: Dr Terry did not advise to "T" piece. Read again as he advises this could create problems.
HQforme Offline
#8 Posted : Friday, 20 March 2009 7:35:51 AM(UTC)
HQforme
Not quite, in an ealier topic he advised i tapp the manifold in 2 places and t-piece those two lines into a single to the PCV valve, thats all.
"Silly modern cars"
jabba Offline
#9 Posted : Friday, 20 March 2009 6:07:37 PM(UTC)
jabba
Also, PCV valves can stick open after a few miles. My old 400 went through them at the rate of around 1 per year. (But that was with unbaffled covers and a tired engine).
Keep the shiny side up, and the gre
Utility8 Offline
#10 Posted : Friday, 20 March 2009 6:48:04 PM(UTC)
Utility8
I recently fitted discs & a booster to a totally stock HR Special. Originally my Granfathers car. It had a fitting in the manifold already, but had a PCV plumbed into it. My dilema was where to connect the booster vacuum line. My dad, the second owner, ha
utility8
cheezel308 Offline
#11 Posted : Saturday, 21 March 2009 2:34:55 AM(UTC)
cheezel308
could this T piece into the rocker cover and manifold be the reason my red 202 is smokey & burns through the oil!?!
HQforme Offline
#12 Posted : Sunday, 22 March 2009 1:49:14 AM(UTC)
HQforme
Quite possible, if youve td the booster and pcv together. If you can pull your manifold off youll probably see oil in there. or even just pull the carby.
"Silly modern cars"
