basketcasebear Offline
#1 Posted : Wednesday, 18 March 2009 5:53:04 AM(UTC)
basketcasebear
i be wondering,
if one connects a charged battery to a third approx charged battery, will the batteries even out their charge.
eg they will end up with about the same amount of charge,,
tanks already
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!"
and the wind did not answer, it just laughed in space.
k.g/
DOH!!!
pont69 Offline
#2 Posted : Wednesday, 18 March 2009 5:59:24 AM(UTC)
pont69
yes they will. they will always = the same charge. and when you drain one. you drain the other at the same time
Cheers, James
Cheers, James
#3 Posted : Wednesday, 18 March 2009 7:49:07 AM(UTC)
basketcasebear
thanks james
bcb
k.g/
DOH!!!
roy1126 Offline
#4 Posted : Wednesday, 18 March 2009 9:48:38 AM(UTC)
roy1126
The best analogy Ive been told to use in this case is that of a U tube and water.
Pour water in to one side of the U tube and it will equalise to the same height both sides.
Same with batteries, the higher charged battery effectively charges the low
kraul Offline
#5 Posted : Thursday, 19 March 2009 10:01:59 AM(UTC)
kraul
basicly if u get the voltage of your two batterys add them together and divide by 2 ull have wat they will be at once connected together.
eg 11v battery and 14v battery join them together and youl get 12.5v
#6 Posted : Thursday, 19 March 2009 5:24:01 PM(UTC)
Actually Krual if you put a 6V battery in parallel woth a 12V battery you will get 6V out, as the 12V battery will discharge trying to charge the 6V one to 12V.
When you connect supplies in parallel they do not charge/discharge/deliver at the same rate
