lgs Offline
#1 Posted : Wednesday, 18 March 2009 12:50:53 PM(UTC)
lgs
I need to remove the ignition from the dash and guess the trick is to unscrew the ign barrel a few turns while inserting something in the pin hole in the front, thats stuck too any ideas??
Iam chasing left rear passenger door trim and rear right top window trim if any one has at the right price.its for my 16year old its his first car.
My older boy has done up HJ, now completing resto on EK and building 42 chev hotrod (got to keepem busy)
thankx heaps
bold
Edited by user Thursday, 19 March 2009 2:52:57 AM(UTC)  | Reason: Not specified
bold
Casper Offline
#2 Posted : Thursday, 19 March 2009 5:38:28 AM(UTC)
Casper
From memory, you have to insert the key, then insert a pin in the small hole.
The barrel assy should pull out then and let you unscrew the collar.
Its been a while though.
darryl Offline
#3 Posted : Thursday, 19 March 2009 7:54:41 AM(UTC)
darryl
I am sure you also have to have the key in the ACC position to remove.
classic oz wreck Offline
#4 Posted : Thursday, 19 March 2009 7:58:27 AM(UTC)
classic oz wreck
darryl is correct...if you cant get it to accessory position see my reply in the hktg ignition removal thread..
www.classicozwreck.com.au
lgs Offline
#5 Posted : Friday, 20 March 2009 2:42:55 AM(UTC)
lgs
The barrel a
bold
