Browno Offline
#1 Posted : Thursday, 19 March 2009 4:11:09 AM(UTC)
Browno
hey all just asking a question on heaters in genral in cars.. i have a daily driver of a hilux and if i bung the out let will this make my heater work? sorry i know its not holden but i know u guys might know?
Drive It Like You Stole It......Drive it like you own it
petaus Offline
#2 Posted : Thursday, 19 March 2009 7:36:31 AM(UTC)
petaus
if you can find the two pipes at the firewall in and out take the hoses off and flush it out with the garden hose, make sure you have water flow through it, check your thermostat is not stuck open, may not heat up enough to make it work, make sure heater
Browno Offline
#3 Posted : Tuesday, 24 March 2009 8:05:41 AM(UTC)
Browno
thanks mate flushed it out made sure heater tap was working worked a treat like a oven now. cheers!
lxtoranahzute Offline
#4 Posted : Tuesday, 24 March 2009 9:47:10 AM(UTC)
lxtoranahzute
When i got my torana the heater hoses were and still are disconected,posibly because it leaks.Wanting to check it without filling up my car with water,Do you think if i used compressed air i would hear a leak or wud i run the risk of blowing it apart lol,
pont69 Offline
#5 Posted : Tuesday, 24 March 2009 8:00:05 PM(UTC)
pont69
LX- your best bet, is remove the outer heaterbox, and take the core out and plug the hose onto it. did that with mine and found 3 fins were oozing.. put some silicone on.. and no leak :P
Cheers, James
Cheers, James
#6 Posted : Wednesday, 25 March 2009 12:06:46 AM(UTC)
lxtoranahzute
ok cheers pont69
