Custom Offline
#1 Posted : Saturday, 21 March 2009 9:16:38 AM(UTC)
Custom
Anyone know what these are from and how you get that yellow retaining spring off that holds the lining in place.
They are early Holden and on an old Caravan I am doing up.
Thanks.
Gary Thorpe Offline
#2 Posted : Saturday, 21 March 2009 6:42:29 PM(UTC)
Gary Thorpe
do you have a pic of the wheel ?
I would not have a clue about internals ut sometimes the type of rims can give a guide.
Gary T
Steel Bumpered Auto Promotions
www.hdhrholden.com
Gary T
#3 Posted : Saturday, 21 March 2009 7:33:47 PM(UTC)
They look like early Valiant or something similar from the 50s or 60s.
To remove the shoe retaining springs, you insert a small/medium slotted screwdriver into the centre of the spring & unhook it from the T-clip at the rear. If you look in behind the
Custom Offline
#4 Posted : Sunday, 22 March 2009 12:05:33 AM(UTC)
Custom
The rims are HR Disc rims, they still have the Olympic Cross Plys on them.
The Van is a late 60s model and I would pressume the brakes are Early Holden.
Anyway thanks for the tip on the springs. I will see how they go.
Regards. Keno.
Custom Offline
#5 Posted : Wednesday, 25 March 2009 7:10:46 AM(UTC)
Custom
You were right on the tip on these brakes Dr Terry.
I took the whole lot down to Lilydale Brake & Clutch today and he took one look at them and said yep Valiant.
He actually had the linings and cylinders on the shelf.
#6 Posted : Wednesday, 25 March 2009 6:29:25 PM(UTC)
Regards. Keno
Utility8 Offline
#7 Posted : Thursday, 26 March 2009 12:51:34 AM(UTC)
Utility8
OK, the identifying 1/8 hole is for HR passenger vehicles? Then no 1/8 hole is for HR commercial vehicles? What wheel would be fitted to a HR Ute with discs? A wheel with a 1/8 hole or without 1/8 hole? I ask as I have just been through the process to fit
utility8
