basketcasebear Offline
#1 Posted : Sunday, 22 March 2009 8:08:18 AM(UTC)
basketcasebear
hey yall.
have a mate with an au falcom,
his heater does not work, it stays on cold,
hoping this might be some elec/electronic switch problemo,
his fuses i think are fine.
q. is the hot water supplied all the time to heater radiator?
q, is the cold or hot air changed over by a vent, and or switch??
fan works okies,
your help with this mucho gracias and appreciated.
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!"
and the wind did not answer, it just laughed in space.
k.g/
DOH!!!
302Superbird Offline
#2 Posted : Sunday, 22 March 2009 11:49:59 AM(UTC)
302Superbird
Is it a base model with air con or an upmarket with climate control?
#3 Posted : Sunday, 22 March 2009 7:07:57 PM(UTC)
basketcasebear
hey 302,
i will get back to you on whether it is base or climate control,
it is a wagon, and it looks from memory n upper market model,
but i will check,
thanks
bcb
DOH!!!
#4 Posted : Monday, 23 March 2009 1:03:28 AM(UTC)
basketcasebear
hey 302 superbird,
it is a aufairmont, with climate control.
it appears to always be on cold no matter what the temp is set at,
both hot water pipes coming out of fiewall are hot, so water must be going into heater rad??
it is easy to access the contr
DOH!!!
#5 Posted : Monday, 23 March 2009 2:11:53 AM(UTC)
302Superbird
I am sure if you hold down 2 buttons simultaneously, it does a self test and gives a fault code, and is easily reset. The problem is I can not remember how to do it on these models. the earlier ones (EB etc) were similar too. Hopefully someone on here who
#6 Posted : Monday, 23 March 2009 2:59:02 AM(UTC)
basketcasebear
thanks heaps superbird,
will try it,
i will get back,
superbasketcasebear
DOH!!!
#7 Posted : Tuesday, 24 March 2009 1:28:17 AM(UTC)
basketcasebear
hey superbird,
thanks heaps,
we did it today,, it worked, held 2 buttons in, and turned the ignition on,,it reset!!!
now he owes me heaps,,cause he has been driving around for 2 years, without heater!!
and would have been hit in the skyrocket, to faul
DOH!!!
