old school coot Offline
#1 Posted : Wednesday, 1 April 2009 1:39:47 AM(UTC)
old school coot
Ive bought some 14x7 HR rims which I was told they'd fit, which of course they don't. I'm having some clearance issues and have bought spacers, however I might have to do some more clearancing on the upper control arms.
I'm going to be putting in longer HQ studs, but what are your thoughts on what else I can do to improve clearance?
Or should I toss it all in the too hard basket and get rims with a more +ve offset?
Utility8 Offline
#2 Posted : Wednesday, 1 April 2009 1:59:15 AM(UTC)
Utility8
What rims do you have? HR only had 13" diameter wheels from factory.
HQ studs? Do you mean HQ stub axles with vented rotors & calipers to suit? If so, the options for wheel choice will be better. But your rear will need to be bought into line with the H
utility8
80737k Offline
#3 Posted : Wednesday, 1 April 2009 2:15:21 AM(UTC)
80737k
As above but ill say this "SPACERS BELONG IN THE BIN".
"Junk is something you throw out three weeks before you need it"
Fossil fuels are YUMMY !
vintageholden Offline
#4 Posted : Wednesday, 1 April 2009 5:10:06 AM(UTC)
vintageholden
14x7 should fit???
hr with disks need 14x7
without disks 13x6 will fit normally???
Dr Terry Online
#5 Posted : Wednesday, 1 April 2009 5:53:58 PM(UTC)
Originally posted by vintageholden
14x7 should fit???
Edited by user Wednesday, 1 April 2009 5:55:20 PM(UTC)  | Reason: Not specified
DreaminHR Offline
#6 Posted : Thursday, 2 April 2009 10:23:20 PM(UTC)
DreaminHR
whats the biggest size wheel that can go on a hr without any mods? does lowered springs on the front and blocks on the back play any part to wheel decision?
adam PERTH Offline
#7 Posted : Friday, 3 April 2009 1:46:10 AM(UTC)
adam PERTH
the lower you go, the more chance of wheel rub on wheel arch.
worse if its a HR premier, as it will rub on your stainless steel mouldings and dislodge them.
i have run 13 x 7 anson sprint and 13 x 8 US indy on rear on HR Premier before with 235 50 and 2
#8 Posted : Wednesday, 22 April 2009 12:18:16 AM(UTC)
old school coot
Thanks for all of the advice. Ive decided to not put on the 14x7 rims on the front, and so am looking for a pair of 14x6 for the front instead - cheaper, smarter, safer option. The 14x7 on the rears are tyred up and ready to go and fit great. Looks tough
FastEHHolden Offline
#9 Posted : Thursday, 23 April 2009 4:22:22 AM(UTC)
FastEHHolden
What bit is doing the rubbing? the centre on the caliper or the top arm on the rim.
I think you best bet if are set on those wheels might be a change to LH-LX-UC Torana stubs and brakes.
Ive just been having the same trouble but mine could be easily
peter_flane Offline
#10 Posted : Thursday, 23 April 2009 4:26:44 AM(UTC)
peter_flane
You cant put Torana stubs on a HR. You can put Torana calipers and discs, but not the stubs. The King Pin Inclination Angle is different and the front end is all wrong.
Utility8 Offline
#11 Posted : Thursday, 23 April 2009 4:29:17 AM(UTC)
Utility8
Torana stubs are probably not an option as the geometry of Torana stubs is not compatable with the HR front end assembly. They will fit up, but are incorrect.
Utility8
[img]http://forum.ejehclubqld.com/ehclub/forum/uploaded/utility8/200812211226_JMB%2
utility8
DreaminHR Offline
#12 Posted : Friday, 24 April 2009 1:52:45 AM(UTC)
DreaminHR
gday guys
I just spotted these rims n was wondering would they fit under a hr pano running lowered springs on the front and reset leafs on the back
Im going to be running a 336 banjo diff and trimatic 202 if this helps at all.
I was going to be havin
Utility8 Offline
#13 Posted : Friday, 24 April 2009 4:57:16 AM(UTC)
Utility8
Dont know. Do some measurements. You gotta find out rim width, back spacing dimensions, rolling diameter of tyre, total tyre width, that will suit your car & your taste. Its one of those things. You gotta try wheels on your particular car. See what youre
utility8
This page was generated in 0.162 seconds.
