#1 Posted : Sunday, 5 April 2009 10:56:38 AM(UTC)
cleaning out the shed found an instrument panel believe its torana it has tacho, a speedo to 200k,and ampmeter,fuel, temp, oil gauges are in one dial, total of 3 squarish dials, is about 350mm long, 100mm high, has number 1 over 475 on top, 9930997 on a tag on the wiring harness.
harness is for the panel only don't have other harness.
Can someone identify and give an idea of value?
thanks.
is in dusty but fair condition plastic facings are dirty but not damaged.
adam PERTH Offline
#2 Posted : Sunday, 5 April 2009 7:15:46 PM(UTC)
adam PERTH
are the numbers in white or yellow?
that will make a big difference to the value.
WANTED:
HZ sandman Van 6/10 or better.
ReplicarSLR Offline
#3 Posted : Monday, 6 April 2009 2:46:27 AM(UTC)
ReplicarSLR
If it has yellow numbers does it also have the brake light at the bottom of the speedo?
#4 Posted : Monday, 6 April 2009 8:42:35 AM(UTC)
tis white numbers and cant see a brake light anywhere.
#5 Posted : Thursday, 9 April 2009 7:48:41 AM(UTC)
no one???
JBM Offline
#6 Posted : Thursday, 9 April 2009 9:01:21 AM(UTC)
JBM
If the needles are white its for an LH, yellow for LX.
James
This page was generated in 0.276 seconds.
