benno Offline
#1 Posted : Tuesday, 7 April 2009 7:37:29 PM(UTC)
benno
howdy! im new to this forum.
i am chasing a bit of info that seems a bit elusive.
i am helping a mate with a budget drag car, and i want to know if a torque converter from a ford cortina or escort 4 cyl (believed to be b/w35??) will slip into a borg warner 40 from an xe falcon. and obviously if it bolts up to the falcon flexplate etc...
same idea as using a holden gemini converter in a 6 cyl trimatic as a budget hi stall for a red/blue 6.
has anyone done this, or know someone who has?? info is hard to come by as most people never use a hi stall in a bw 35/40 for obvious reasons - theyre not a performance transmission!
appreciate any leads.
regards ben
Browno Offline
#2 Posted : Thursday, 9 April 2009 5:09:41 AM(UTC)
Browno
g'day pretty sure there the same box just ones a bit more heavy duty so should match up fine dont think it would be any higher stall then the orginal. if ur good and u have a spare converter u could change the angle of the fins urself never done this myse
Drive It Like You Stole It......Drive it like you own it
This page was generated in 0.083 seconds.
