hztonner Offline
#1 Posted : Saturday, 11 April 2009 9:55:06 PM(UTC)
hztonner
HI IF ANYONE CAN PLEASE TELL ME THE DIFFERENCE BETWEEN THE {DRAG LINKS AND IDLER ARM} ON HQ TO HX AS I HAVE REBUILT MY HZ ONE TONNER
AND WENT TO PUT THE STEERING ARMS BACK ON BUT THEY WILL NOT FIT OR COMMECT TO THE TIE-ROD END DRIVER SIDE OK BUT LEFT HAND SIDE WILL NOT LINE UP WHAT DO I HAVE TO CHANGE TO MAKE FIT IS THERE ANY DIFFERENCE WITH THE {DRAG-LINKS} AS THE WORK SHOP MANUALS I HAVE TELL ME NOTHING OR IS THERE ALSO ANY DEFERENCE JUST WITH THE (IDER ARM) PLEASE LET ME KNOW WHAT I NEED TO FIX OR CHANGE
(HI ITS NOT POWER STEERING)
old fart racing the older i get the faster i was
Edited by user Sunday, 12 April 2009 6:21:45 PM(UTC)  | Reason: Not specified
vintageholden Offline
#2 Posted : Sunday, 12 April 2009 6:17:55 AM(UTC)
vintageholden
do you have power steering as i think there different
Mr Void Offline
#3 Posted : Sunday, 12 April 2009 6:27:45 AM(UTC)
Mr Void
powersteering is definately different to non. From memory the turning circle created by the p.s setup is tighter.
___________________
Why are you reading this, you should be looking up there^^
- HJ turbotonner looks and goes like a sneezing rhino on
___________________
#4 Posted : Sunday, 12 April 2009 6:29:47 AM(UTC)
How you goin man? I would take a mental note and photo in a digital camera an go to the nearest wreckers,it works Ive had to do it a few times.From memory the steering arms can be different lenghts(Power steer/not),but as I said the wreckers is a place wh
states_man Offline
#5 Posted : Monday, 13 April 2009 3:11:21 AM(UTC)
states_man
I believe the drag links for HZ and WB are different to Hq- HX, the HZ WB ones suit radial tuned suspension cars while the Hq-HX ones suit non RTS cars,you may have the wrong drag link, also power steer cars have shorter steering arms while non power stee
hztonner Offline
#6 Posted : Monday, 13 April 2009 4:38:39 AM(UTC)
hztonner
thanks for help i will now have to get the right part thanks
