bundybluedog Offline
#1 Posted : Tuesday, 14 April 2009 3:31:07 AM(UTC)
bundybluedog
Does anyone here have an origanal lc sedan 6 cyl throttle linkage. and what are they worth.
dagwoodone Offline
#2 Posted : Tuesday, 14 April 2009 4:34:53 AM(UTC)
dagwoodone
the firewall one or the firewall to carby and is it a gtr or a standard 6
dagwoodone Offline
#3 Posted : Tuesday, 14 April 2009 4:36:55 AM(UTC)
dagwoodone
oooops shouldve realised you said sedan
#4 Posted : Tuesday, 14 April 2009 5:33:56 AM(UTC)
bundybluedog
when i bought it it had a 253 in it done dodgey and has a cable tied to an L shaped bracket infront of the brake booster so i have no idea what its spose to look like. i just wanna put a 6 in it while the funds are low so at least i can drive it instead o
3100x Offline
#5 Posted : Tuesday, 14 April 2009 6:02:49 AM(UTC)
3100x
first all LCs are sedans, on the ADR plate
I have a LJ 6 with a cable throttle so you should be able
to adapt the cable you have by mounting a bracket on one
of the manifold studs to use it on the 6,
or bits can be used from a LX,
thats if you are g
Guest (5)
