Docktor Offline
#1 Posted : Wednesday, 15 April 2009 7:23:44 PM(UTC)
Docktor
Hey Yas. Ok I am putting electric seat bases in my xc. I have seat bases from " 1974 ltd ". (i used to own a 74 ltd and it didnt have leccy seats). But I am going by what the bloke told me. I have a zk/zl leccy seat switch assembly. What I need is a wiring diagram for either the seats or the bases or both at best. I just need a starting point so I dont let the smoke outta the motors coz i imagine they will be hard to find a good set again.
Bases and switch =
http://cgi.ebay.com.au/w...WNX:IT&item=280322998304
http://cgi.ebay.com.au/w...WNX:IT&item=180339166424
79fairlane Offline
#2 Posted : Thursday, 16 April 2009 5:13:58 AM(UTC)
79fairlane
As far as i know all the bases from P5 LTD up to XF/ZL/FE are the same, only the switches differ. You'd be best to go to supercheap, look at a gregorys manual, and copy down the schematic from the model that the switches came from and wire accordingly.
76 ZH Marquis
79 P6 LTD Town Car
01 XR8
basketcasebear Offline
#3 Posted : Tuesday, 21 April 2009 5:19:03 AM(UTC)
basketcasebear
hey dok.
i wired in merc elec seats into my 98 transit.
fun and games aplenty!!
what i did, with out the merc control panel was> wire in one main polarity switch, that supplies each momentary switch for each motor in the seat,
from each momentary
DOH!!!
Docktor Offline
#4 Posted : Tuesday, 21 April 2009 6:52:51 PM(UTC)
Docktor
Hey Blokes. I have the switch from what i suspect is a fairlane/ltd, I havent as yet fired the switch up as i dont have a wiring diagram for it and dont wanna burn it out. I am hoping the reverse polarity switch it built in and all i have to do is find my
79fairlane Offline
#5 Posted : Wednesday, 22 April 2009 5:49:30 AM(UTC)
79fairlane
nope, cant take a pic of the switch, as my marquis isnt fitted with them, but they are different to the ones you have. ZH switches are rectangular chrome jobbies that mount separately to each seat base.
I did manage to dig out a switch wiring block fro
76 ZH Marquis
79 P6 LTD Town Car
01 XR8
Docktor Offline
#6 Posted : Wednesday, 22 April 2009 10:50:35 PM(UTC)
Docktor
Thanks Nathan. Colours seem to match. I was gunna cut my switchblock into my xc centre console but the console isnt wide enough, doh. next thing is to get some zh power seat switches i guess. at least the wiring makes sense now,, tested the seat bases an
landau37 Offline
#7 Posted : Monday, 4 May 2009 9:40:27 AM(UTC)
landau37
I have the zh marquis seats that i am going to put in my landau, my p5 seats wernt eletric .I have the rectangle switch set ups on each seat with 2 switches on each with a toggel in the midle of each. I was hopeing that once the power was hooked up that t
c.rice
79fairlane Offline
#8 Posted : Tuesday, 5 May 2009 4:57:42 PM(UTC)
79fairlane
One you hook the power up the seats should work. If they dont , check the condition of the pins on the back of the switch block and the contacts in the black plastic plug. The seats also have a habit of jamming up (grease in the gearboxes goes hard and
76 ZH Marquis
79 P6 LTD Town Car
01 XR8
Guest (6)
