Vintage Caravans Offline
#1 Posted : Thursday, 16 April 2009 1:11:49 AM(UTC)
Vintage Caravans
Just about to change the red 186 I have to a trimatic, and was wondering if there is a difference in spigot bush from manual transmissions to Trimatic?
Also where can I buy a spigot bush from as mine was a CRS one that I have removed (way to small - it was for a toyota conversion) are they still available new?
Matt
79 F100 XLT 351, 62 EK 327 Wagon, 62 EK 327 Ute 62 EK 307 Van 90
Hmmm I see a pattern forming!!
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
adam PERTH Offline
#2 Posted : Thursday, 16 April 2009 4:50:52 AM(UTC)
adam PERTH
take the spigot out and just run the Auto without one.
Hang onto the Toyota spigot, someone on here will need it sooner or later i am sure.
WANTED:
-HZ GTS steering wheel, buckskin.
-2 x 15 x 8 Dragway centrelines
Browno Offline
#3 Posted : Thursday, 16 April 2009 4:52:14 AM(UTC)
Browno
is the internal diameter to small? just machine it bigger at a machine shop or something
Drive It Like You Stole It......Drive it like you own it
peter_flane Offline
#4 Posted : Thursday, 16 April 2009 5:07:43 AM(UTC)
peter_flane
Does the auto have one?
#5 Posted : Thursday, 16 April 2009 5:10:49 AM(UTC)
Vintage Caravans
Thansk for that ADAM,
can you run it without a Spigot bush?
Browno, yeah MILES too small, I didnt want to machine it out as I will sell the complete set up for a Toyota box to red motor
#6 Posted : Thursday, 16 April 2009 5:12:12 AM(UTC)
Vintage Caravans
Hi Peter, I am not sure if they do or not? I presume they did???
Edited by user Thursday, 16 April 2009 5:36:11 AM(UTC)  | Reason: Not specified
peter_flane Offline
#7 Posted : Thursday, 16 April 2009 5:37:17 AM(UTC)
peter_flane
No I mean does the Trimatic actually have spigot bush in the crank. The torque converter bolts to the flex plate and they all turn with the crank, so there is no bushing needed unless it is for centring purposes! Or does the torque converter have the same
#8 Posted : Thursday, 16 April 2009 6:01:30 AM(UTC)
Was thanked: 605 time(s) in 572 post(s)
From memory there is a little spigot that goes in the end of the crank for a 6cyl Trimatic. V8s dont have one.
#9 Posted : Thursday, 16 April 2009 6:03:04 AM(UTC)
Vintage Caravans
that is the one I am looking for!
Matt
79 F100 XLT 351, 62 EK Wagon-327, 62 EK Ute-327, 62 EK Van-307 62 EK Sedan-202
Spot the odd one out??!!
#10 Posted : Thursday, 16 April 2009 8:30:43 AM(UTC)
Hi Vintage Caravans.
They do run a spigot bush if you have a look here
http://holdenpaedia.oldholden.com/Spigot_Bush
There are pictures of one in a crank and out.
Over here in WA I would say get one from Coventrys a WA parts supply place but in the e
peter_flane Offline
#11 Posted : Thursday, 16 April 2009 9:06:13 AM(UTC)
peter_flane
Locator, that is the name. I do remember now. I had to remove the CRS spigot, which I gave to a mate, and the locator was supplied by the engine builder.
#12 Posted : Thursday, 16 April 2009 9:15:44 AM(UTC)
several years since I did my manual to auto but I am pretty sure I had to leave the spigot bush out.
I can clearly remember removing it with globs of grease everywhere.
if you do need one they are easily available. If I was fitting one I would go for
#13 Posted : Thursday, 16 April 2009 6:55:38 PM(UTC)
Vintage Caravans
Thanks a million guys, my local rare Spares were unsure so I thought I had better ask on here - they were looking for a spigot not a locator!
Matt
