jayHK69 Offline
#1 Posted : Sunday, 19 April 2009 2:48:21 AM(UTC)
jayHK69
just wanting to know the best thing to do with my motor. it`s already installed in the car but due to health problems car wont be back on the road for about 12 months now.
motor has been rebuilt, all sealed up, never been started.
do i regularly pull the plugs drop a bit of oil down the holes & turn over by hand or just leave it ? or ?
your advise is greatly appreciated
jayson
DreaminHR Offline
#2 Posted : Sunday, 19 April 2009 3:29:11 AM(UTC)
DreaminHR
hey Jay
Im sure other blokes will have more specific info for you but i was told by my engine guy to just make sure all its holes are covered and to put a sheet or something over it so that any moisture in the garage or shed will not not reach the motor.
jabba Offline
#3 Posted : Tuesday, 21 April 2009 11:51:40 PM(UTC)
jabba
Run it up to temp about once a month, good idea at the same time to move the vehicle backwards and forwards a bit (or once around the block / paddock) to prevent tyres deforming where they are resting on the grounds and turn everything else over.
_____
jayHK69 Offline
#4 Posted : Friday, 24 April 2009 3:39:42 AM(UTC)
jayHK69
thanks guys your help is appreciated
jayson
hazzard county Offline
#5 Posted : Friday, 24 April 2009 5:00:03 AM(UTC)
hazzard county
make sure all the rockers are released so there is no pressure on valve springs if the engine is out of the car drop your sump grab a can of what they call engine honey made by moley by memory this is what some mechanics use when putting an engine togethe
