#1 Posted : Sunday, 19 April 2009 4:20:12 PM(UTC)
Can you tell me what month and year did the upper 1/4 vents get deleated?
#2 Posted : Sunday, 19 April 2009 7:17:00 PM(UTC)
Not exactly. It was in the vicinity of 6/74. 4/74 and 5/74 seem to have them but 7/74 seem to not. Not sure if its plant dependant either (ie all at the same time or not), remembering that in HQ Elizabeth, Acacia Ridge, Pagewood all made their own van bod
#3 Posted : Sunday, 19 April 2009 7:31:34 PM(UTC)
adam PERTH Offline
#4 Posted : Sunday, 19 April 2009 8:40:03 PM(UTC)
adam PERTH
when did they start.
I have seen HG with them.
WANTED:
-HZ GTS steering wheel, buckskin.
-2 x 15 x 8 Dragway centrelines
#5 Posted : Sunday, 19 April 2009 9:06:56 PM(UTC)
I believe all panelvans up until late HQ had them.
#6 Posted : Sunday, 19 April 2009 9:42:41 PM(UTC)
Thats correct. The van roof used on HQ-WB is actually the same basic roof as on HK-HG, and the HK-HG on is basically what was on HD/HR. Look at them closely side by side and you can see what I mean. Even the upper tailgate on HQ-WB, put one side by side w
Edited by user Sunday, 19 April 2009 9:48:43 PM(UTC)  | Reason: Not specified
classic oz wreck Offline
#7 Posted : Sunday, 19 April 2009 9:48:27 PM(UTC)
classic oz wreck
actually they extended the hktg upper tailgate for hq to wb...hktg upper fits the hole of hq to wb but its a couple of inches short..
www.classicozwreck.com.a
www.classicozwreck.com.au
#8 Posted : Monday, 20 April 2009 2:41:31 AM(UTC)
Yes, those side vents on panel vans were around in various forms since the first FJ van.
Id have to agree with HK1837, at around 6/74 for the last of the side vents.
The upper tailgate glass is the same on panel vans, from HD to WB.
DreaminHR Offline
#9 Posted : Monday, 20 April 2009 8:49:08 AM(UTC)
DreaminHR
Is it only the glass thats the same?
Ive been trying to source out a good upper tailgate for my hr but i cant seem to have any luck finding one worth using
cheers mick
#10 Posted : Monday, 20 April 2009 3:50:14 PM(UTC)
Check first, but from memory the HK-HG tailgate is the same as HD-HR. HQ-WB is taller but could possibly be used to repair an earlier one.
If we all had the same (good) taste, who would buy all t
HZ_Premier Offline
#11 Posted : Monday, 20 April 2009 8:42:01 PM(UTC)
HZ_Premier
If you look at it the extra height on the HQ-WB is in the 2" - 4" band added to the bottom of the gate, yes gates are all the same just height added to them,
i was once told also the rofs are all the same and the front extended, now makes sense look a
Living the Dream
#12 Posted : Monday, 20 April 2009 9:36:58 PM(UTC)
The roof panel is not extended. The turret pressing, as its called from the gutter line upwards, is the same piece from HD to WB.
Edited by user Monday, 20 April 2009 9:38:22 PM(UTC)  | Reason: Not specified
HZ_Premier Offline
#13 Posted : Monday, 20 April 2009 10:20:21 PM(UTC)
HZ_Premier
so this is the shonky join you can see above the door?
Living the Dream
Living the Dream
