GMH Offline
#1 Posted : Tuesday, 21 April 2009 5:04:59 AM(UTC)
GMH
I was told to advance the timing in my VL NA to get a bit more power out of it, does anyone know if this will help...
it is also running on dual fuel, if i pull this system out and get it retuned and new injectors will i also get more power out of it or not?
this is just a w/e car
jabba Offline
#2 Posted : Tuesday, 21 April 2009 11:40:05 PM(UTC)
jabba
Suggest ditching the dual fuel and running straight gas. That will let you advnce the timing further without causing detonation.
FastEHHolden Offline
#3 Posted : Thursday, 23 April 2009 4:16:41 AM(UTC)
FastEHHolden
The usual trick is to advance the cam one tooth...and it does help...Ive done it.
