DreaminHR Offline
#1 Posted : Wednesday, 22 April 2009 9:38:07 AM(UTC)
DreaminHR
Gday
Ive got a question regarding hr pano roof linings, I am unable to source out the rods that hold up the roof lining and i am wodering if i could maybe source out some from a different model?
Also does any parts from a sedans roof lining fit with the panos? Do i have any other options i havent thought of?
cheers in advance
#2 Posted : Thursday, 23 April 2009 4:29:41 PM(UTC)
Hi Mick, I was reading in another topic that the roof went from HD-WB so I would guess the rods/bows that hold the headlining up would have to be the same? HQ-WB the upper 1/4s were extended so I would try a HK-HG set of rods/bows. Below is the info from
Edited by user Thursday, 23 April 2009 4:30:45 PM(UTC)  | Reason: Not specified
#3 Posted : Thursday, 23 April 2009 5:51:38 PM(UTC)
No, I dont think that the HQ-WB bows will do the job.
The part of the panel van below where the turret panel attaches is different & on the later models, much wider.
AFAIK the only bows that will fit properly are the HD/HR ones.
Dr Terry.
#4 Posted : Thursday, 23 April 2009 6:39:30 PM(UTC)
Doc I pointed out the upper 1/4s were extended on HQ-WB, But if you are saying that the roof is the same, Byron pointed out that HK-G the rear upper gate is the same and I know the HK-G floor is 95% the same then there is a fair chance the bows in a HD-R
DreaminHR Offline
#5 Posted : Thursday, 23 April 2009 9:57:04 PM(UTC)
DreaminHR
thanks guys for the feedback, i read that other post and was thinking the same thing but didnt think it would be a good idea to jump on someone elses topic.
ill have a search to see how i go with getting the bows from a hk-g model and i can only check he
