joerossetti3131 Offline
#1 Posted : Monday, 27 April 2009 8:52:50 AM(UTC)
joerossetti3131
Hey
Im new here.
I have a 1991 VN Berlina commordore. It has done close one 260,000 ks
I was given the car.
As i cannot afford the petrol, I have the choice of selling the car for around 1k and buying a corolla.
Or converting it to gas.
After gov rebate, it will cost me around $300 with EZY-GAS
Is it a good idea to convert? As i here holdens dont handle gas well
I only plan to have to car for 3-5 years longer, as long as possible, as i am a student and dont wish too put large amount of money into it.
If i do convert it, should i put it to srtaight gas? or duel fuel.
Also, is EZY-GAS the best and reliable?
Joe
vintageholden Offline
#2 Posted : Monday, 27 April 2009 10:38:45 AM(UTC)
vintageholden
i,m a gas fitter...(AAA Autogas welshpool W.A 94705090)
and fit lpg to commodores all the time .they run very well on gas...
straight gas is better......
keith
#3 Posted : Monday, 27 April 2009 6:08:43 PM(UTC)
Keith, what makes you say that straight LPG would be better on a V6 Commodore. I would agree on an older carby V8s, where you can delete the carby & fit a good large converter. But what advantage is there in going straight gas on an EFI V6.
I too am a
Edited by user Monday, 27 April 2009 6:28:34 PM(UTC)  | Reason: Not specified
musksell Offline
#4 Posted : Monday, 27 April 2009 6:53:10 PM(UTC)
musksell
basically any big motor with hydraulic tappets does alright on gas, which the V6 has.
What or how does this positive pressure system for lpg work Dr Terry... Is it also impco...?
have you any photos...? website..?
#5 Posted : Monday, 27 April 2009 9:18:58 PM(UTC)
joerossetti3131
Hey,
Cheers for your replies.
I think i will convert it to gas. Straight gas cost more as well. and i dont think its worth the hassle.
Ill let ya know how it pans out.
#6 Posted : Tuesday, 28 April 2009 1:10:17 AM(UTC)
vintageholden
gas needs more advance than petrol
tuning between the 2 is hard to get each one to perform at its best
straight gas you can tune the motor better also can build a higher compression motor
get it chipped as well for dedicated gas.....
impco 225 arnt
Edited by user Tuesday, 28 April 2009 1:15:07 AM(UTC)  | Reason: Not specified
adam PERTH Offline
#7 Posted : Tuesday, 28 April 2009 1:47:36 AM(UTC)
adam PERTH
You are a member of these groups:: Registered, Veteran
Kieth.
2 weeks ago i had a brought a VP wagon for $360, licenced , and dual fuel, but the gas isnt working and the conversion is more than 10 years old.
can i get the tank recertified and put a fresh converter in there and get the car re certified and
Rhys Offline
#8 Posted : Tuesday, 28 April 2009 2:23:58 AM(UTC)
Rhys
Adam,
Does it say LPG/PET on the rego papers already or just PET?
Ive heard of people doing that, but I also heard they were cracking down on it.
Rhys
#9 Posted : Tuesday, 28 April 2009 4:09:20 AM(UTC)
vintageholden
if its been lic with lpg allready then no....
tank will cost about $400+
and the converter about the same.i might have a second hand one...OMVL.
