#1 Posted : Thursday, 25 November 2004 9:40:41 PM(UTC)
I'm in the last stages of getting my factory air on my HZ Premier working again, has been a battle let me say!! Anyway the factory thermo fan on the front of the radiator works, however it has been disconnected and the wiring just hangs loose in front of the radiator. Where does this wiring go, and does it hook up to a thermostat somewhere or does it kick in and out with the compressor??
Peter
#2 Posted : Friday, 26 November 2004 1:01:32 AM(UTC)
The thermo fan is fed from a relay. The relay is controlled by a temperature sensor in the radiator.
Warren
#3 Posted : Friday, 26 November 2004 3:49:10 AM(UTC)
Hi Guys.
As Warren says the fan operates by temperature, the sensor is in the radiator top tank (passenger's side) & a relay mounted nearby.
It also requires the A/Cond to be switched on to work.
In other words it only comes on when
#4 Posted : Friday, 26 November 2004 7:59:16 PM(UTC)
Thanks guys, I will go searching and will hook it up again!
Regards
Peter
