#1 Posted : Thursday, 25 November 2004 10:36:51 PM(UTC)
I think i may have got some bad fuel. I have replaced fuel filter and still have the car chugging with a bit of pressure. Does anyone know how to get rid of the bad fuel
#2 Posted : Friday, 26 November 2004 7:12:37 PM(UTC)
Drain the tank. Might be you fuel pump if its not electric. Mine was mechanical and had a small rip in the rubber diaphram that caused it to do that. drain the fuel from your bowl too, if its carby, if not carby then try and injector clean
#3 Posted : Saturday, 27 November 2004 12:50:12 AM(UTC)
Thanks. I only bought a new fuel pump about a year ago. Must be faulty
#4 Posted : Saturday, 27 November 2004 2:29:49 AM(UTC)
If chugging changed after the fuel then its probably the fuel. The grade of fuel we get now, or since the 4c off deal came with food receipts has made them inport cr@p fuel from overseas.
If it changed when u replaced the filter, maybe some crap ma
#5 Posted : Saturday, 27 November 2004 7:35:56 PM(UTC)
Shane
When engines start missing or running rough under load or acceleration, nine times out of ten the problem is electrical.
Many people automatically blame dirty fuel but that is rare. If you did get some dirt in the tank it will usually s
