sparkzy Offline
#1 Posted : Friday, 29 May 2009 2:51:37 AM(UTC)
sparkzy
Hi I just replaced flywheel and put every thing back together and turned over engine and starter motor smashed all the teeth off.
Could I get some help please as to what I did wrong.
Car is a xf 91 model.
Edited by user Friday, 29 May 2009 8:15:03 AM(UTC)  | Reason: Not specified
FORD MUSCLE
302Superbird Offline
#2 Posted : Friday, 29 May 2009 6:19:41 AM(UTC)
302Superbird
Did you compare the old flywheel to the new one, count the teeth and check the setback of the teeth? The starter motor did not have a spacer and you left it out, I don't think that model had spacers.
Can't help you on that model, but I know Clevelands ha
Docktor Offline
#3 Posted : Friday, 29 May 2009 7:31:38 AM(UTC)
Docktor
bein a xf , i would say its a 6 cylinder offhand ?.
my guess is ya didnt put the torque convertor all the way back into the box.... you drop it on the input shaft, turn it half a turn and push, it should drop deeper into the bellhousing. I usually spi
sparkzy Offline
#4 Posted : Friday, 29 May 2009 7:54:09 AM(UTC)
sparkzy
Hi it is 6 cylinder and its auto, torque convertor is all the way back or bell housing wont bolt to engine.
I brought fly wheel off ebay and it looks cheap metal like cast iron that the ring is made from.
I have spent 2 days work on this and cry cry
FORD MUSCLE
Docktor Offline
#5 Posted : Friday, 29 May 2009 8:23:28 AM(UTC)
Docktor
Edited by user Friday, 29 May 2009 8:24:55 AM(UTC)  | Reason: Not specified
#6 Posted : Friday, 29 May 2009 10:03:24 AM(UTC)
You din't put the new flex plate on backwards did you?
A mate of mine did this with a 302W and the engine locked solid when he got it all back together.
sparkzy Offline
#7 Posted : Saturday, 30 May 2009 8:57:46 PM(UTC)
sparkzy
I just hade a look and it only fits one way for xf so it went on the right way, when I put the tourque converter on I fixed it to the flex plate then put the geaar box on. Is this where I went wrong as Docktor said I didnt get tourque converter all the wa
FORD MUSCLE
#8 Posted : Saturday, 30 May 2009 9:12:21 PM(UTC)
302Superbird
The torque convertor slips into the tranny bellhousing, rotate and push it in, you should feel it slot back about 3 times on the shaft and then it is home all the way. I usually support the convertor on the centre knob to hold it square when pushing it in
Docktor Offline
#9 Posted : Sunday, 31 May 2009 2:40:14 AM(UTC)
Docktor
how did you get your flex plate bolted to your crank if you had already bolted the flex plate to the torque convertor ??. Ohhh u bolted the flex plate to the crank, then bolted the torque convertor to the flex plate and then hung the box off the back of i
Edited by user Sunday, 31 May 2009 2:42:36 AM(UTC)  | Reason: Not specified
#10 Posted : Wednesday, 3 June 2009 1:01:15 AM(UTC)
Fly wheel = manual flexplate = auto usually.
If at first you don't succeed then skydiving is not for you.
sparkzy Offline
#11 Posted : Monday, 8 June 2009 3:21:36 AM(UTC)
sparkzy
Thanks guys for your help, flex plate is on and all working like new.
FORD MUSCLE
Guest (5)
