Exdub Offline
#1 Posted : Thursday, 25 June 2009 10:13:19 PM(UTC)
Exdub
Hey Guys,
I've got an XW Ute and i was wondering what options ive got for adding extra fuel? is there a long rang tank available that will fit or will i have to do some mods to make something else fit adn work.
Any help would be great
Scott
Some days your the bug, Others your the windshield
#2 Posted : Thursday, 25 June 2009 10:33:01 PM(UTC)
The existing fuel tank is where the right rear footwell would be in a sedan/wagon. You can add a second tank to the other side of the tailshaft tunnel and run a main plus reserve tank setup.
Exdub Offline
#3 Posted : Thursday, 25 June 2009 10:43:31 PM(UTC)
Exdub
Do you have any more info on the mains reserve tank set-up??
I was thinknig balance pipe between the two tanks?
#4 Posted : Wednesday, 1 July 2009 2:59:16 AM(UTC)
Maybe two electric pumps and a switch between them or just a pump in the reserve tank to fill up the main tank when it runs dry but you would have to have a float valve or an overflow back to the reserve tank for when the main tank is full.
A balan
