Mr HT gts Offline
#1 Posted : Tuesday, 30 June 2009 3:13:20 AM(UTC)
Mr HT gts
Hey everyone,
I fitted a new rare spares door rubber to the passenger side front of my XY.
I have covered it in rubber magic and it has sat now for almost 3 weeks, I have opened and closed it a few times checking on it but it is as stubborn as when I first put in on.
The rubber magic seems to have helped but only just, I still need to slam the hell out of the door to shut it.
the door rubber from rare spares seems to be a copy of the orignal ford tube style.
Are these repo door rubbers garbage ? or will it take more time to bed in ? you can see the bottom corner of the door underneath the handle buldging out, there is a lot of pressure on the door.
any help would be great,
Cheers guys.
keithholden Offline
#2 Posted : Tuesday, 30 June 2009 7:38:30 PM(UTC)
keithholden
My boot lid with new rubber I had to adjust the latch to give a we bit more room, other wise I was slaming it.
prob just need to adjust the striker a little
The doors have prob been off at some stage and would of been adjusted to the old rubber
If
Mr HT gts Offline
#3 Posted : Wednesday, 1 July 2009 6:05:44 AM(UTC)
Mr HT gts
Thanks for the advice Keith, I had considered that but I really didn't want to go screwing around with the doors themselves, but I'm glad I did, I moved the striker out a little bit and it has helped a lot.
I dont need to smash the door closed anymore
CLASSIC AND MUSCLE CARS Offline
#4 Posted : Sunday, 5 July 2009 7:08:51 AM(UTC)
HI, WE HAVE HAD GREAT FEED BACK FOR OUR XY DOOR RUBBERS FROM ALL OVER AUSTRALIA & OVERSEAS.WE ARE CURRENTLY HAVING ALL NEW TOOLING MADE WITH TODAYS TECHNOLOGY.THE TOOLING USED WILL MAKE IN EXCESS OF 1 MILLION ITEMS WITH OUT DETERIORATING.THE RUBBER (YES R
PAUL HARRISON
keithholden Offline
#5 Posted : Thursday, 30 July 2009 8:31:05 AM(UTC)
keithholden
Re your question,,,I am really struggling to open the door from the inside, could this be because the rod is bent ? I really need to squeeze the handle due to the pressure of opening the door?
Im not positive but im thinking adjusting the striker highe
keithholden Offline
#6 Posted : Thursday, 30 July 2009 8:33:16 AM(UTC)
keithholden
Or the stiker is set to high.
