BREDBO Offline
#1 Posted : Friday, 3 July 2009 7:32:07 AM(UTC)
BREDBO
Failed the nsw reg brake pressure test.The mechanic said I may be using wrong master cylinder.Front discs are XB rotor using Holden girloc calipers/rears are Ford 9 inch drums.XD master cylinder with a gemini booster. Did the XD master cylinders vary in bore size and if so which was the largest.The rear slave cylinders are in good condition but are unknown size. Any help would be appreciated.
#2 Posted : Tuesday, 7 July 2009 2:31:26 AM(UTC)
What sort of car are we talking about here? I presume a Capri or maybe an Escort or Cortina.
The smaller bore of the HQ callipers is your main problem. you need to match them up to a smaller master cylinder which in turn may produce too much pressur
BREDBO Offline
#3 Posted : Tuesday, 7 July 2009 4:10:50 AM(UTC)
BREDBO
Are the commodore master cylinders 13/16 inch?. I take it that is a disc/drum set-up type. The car is a 34 ford 3 window coupe. I have the master cylinder mounted under the floor so space and mounting points are all issues.
I had the same brake set up
#4 Posted : Tuesday, 7 July 2009 7:47:56 AM(UTC)
ok I've looked through a few workshop manuals that I have.
XR/XT 1.25"
XW 1.0"
EA-ED 23.81mm Front 31.75mm Rear obviously a stepped bore
XE 25.4mm (1 inch)
Commodore VL 23.8mm standard 6cyl 25.4mm (turbo and V8)
I have workshop manuals for VN
BREDBO Offline
#5 Posted : Wednesday, 8 July 2009 7:27:18 AM(UTC)
BREDBO
Thanks for the information I shall check out the local wreckers for a vl cylinder and check out others that are smaller than 25.4mm bore.
#6 Posted : Wednesday, 8 July 2009 8:12:04 AM(UTC)
I think that any Pre VN Commodore rear drum one will do.
If at first you don't succeed then skydiving is not for you.
#7 Posted : Wednesday, 8 July 2009 4:21:29 PM(UTC)
There's only 2 sizes used in VB-VR commodore - 15/16 and 1".
Regular VB-VR 6 cylinder (and some V8) commodores had 15/16" master cylinders, irrespective of disc or drum rear.
There are internal diffferences between disc & drum, so if you need a drum
Guest (5)
