Bossy Offline
#1 Posted : Saturday, 29 August 2009 4:31:36 PM(UTC)
Bossy
Looking for a Holley 350 and manifold to suit an XF motor that lives in an XP.
#2 Posted : Tuesday, 1 September 2009 1:10:16 AM(UTC)
Cheaper to just get an adapter to bolt the Holley 350 onto your Weber manifold unless you are after longer runners that is. If your Weber is in good condition a Holley 350 will just use more fuel for very little gain in performance.
I replaced the H
Bossy Offline
#3 Posted : Tuesday, 1 September 2009 3:52:34 AM(UTC)
Bossy
Jim, the weber is hard to start due to all the emission control stuff. I have removed the thing off the manifold that connects over to the headers, as it didn't fit in the XP. Holley will be simpler, I believe.
#4 Posted : Tuesday, 1 September 2009 7:51:30 PM(UTC)
Fair enough about the Holley being simpler.
I never had any hassles plumbing the Weber up to a 1971 Val. It did take a while to adapt to the inlet manifold though. The only real problem that I have is that the seals have all dried up now from a lack o
Bossy Offline
#5 Posted : Wednesday, 2 September 2009 6:13:19 AM(UTC)
Bossy
I agree. I think the problem I have is with all the emission control stuff on the Weber. Having got rid of the electric choke it is starting a little better.
Jim, I'm still looking for a manifold for the Holley to the alloy head. Any ideas?
#6 Posted : Wednesday, 2 September 2009 8:42:43 PM(UTC)
Hardiman Redline would probably be a good manufaturer to start with:
http://www.redlineauto.c...oducts/category/QTKGUMTB
Although there are other good suggestions here:
http://www.fordforums.co...e/index.php/t-27056.html
Guest (7)
