abc Offline
#1 Posted : Thursday, 3 September 2009 4:31:48 AM(UTC)
abc
Have installed a 24mm front sway bar on GT Capri, however I notice from the grease marks that the actual bar must be shifting left and right through the bushes and brackets whilst driving. Is this normal for movement to occur? I had also replaced the tie rod ends and steering arms which the bar connects to.
#2 Posted : Thursday, 3 September 2009 11:20:29 PM(UTC)
Yes that movement is normal.
If at first you don't succeed then skydiving is not for you.
This page was generated in 0.022 seconds.
